When I get on the binders after exiting a tight corner (pulling over 1G according to my G-tech meter) the brake pedal almost goes to the floor. Pressing the brake again yeilds normal stopping power. The only thing I can think of that would cause this would be the brake disc moving and pushing the piston back into the caliper. The energy from pressing the pedal is used to push the brake pad back up to the surface of the rotor. I can not notice a handling problem or hear anything odd. I also checked the wheel bearings and can not feel any play. Has anyone encountered this problem before? If the wheel bearings are fine is it just that my bearings/uprights are not up to the task of driving that hard? Does anyone make upgraded wheel bearings?
Suspension Mod List:
1994 Eclipse GS
KYB AGX (set on 2 front, 3 back)
H&R Springs
Full Poly bushing Kit
Front and rear strut tower bars
RRE SS brake lines
Axxis Metal Master Pads
Yoko AVS ES100's, 215-45-ZR17
Remanufactured halfshafts
1994 Eclipse GS
H&R Springs
RRE SS brake lines
