240sx SOHC ignition problem please help
  • 240sx SOHC ignition problem please help
    ok we had the mototr running fine then i just bolted on my body kit and got it ready to take out last night and then i try and start it again last night and it just cranks and we have no spark....the only thing i noticed is that the mount for the coil pack is really really really hot to the touch....so would this be a short or what is happening to make the coil pack mount get really really hot and me losing spark...........any suggestions will work and thank you
    --Ryan
    sounds like you answered your own question. That has all the characteristics of a loose connection or a short.
      I know that with coils, if the coil is improperly grounded (the coil isnt seated tight enough, the body has a bad ground, ect.) the coil gets extreemly hot, and there is no spark.
      I would check all of your grounds first, you might have undone something while putting on the body kit.
        You have a SOHC and have coil packs???? Did you swap to SR or KA24DE? Normally SOHC have distributors.
          coil singular.....and 14yearolddrifter.....you are a avatar theif.
