s13 wheel offset
  • s13 wheel offset
    Im trying to get 15 inch rims, i've looked at 5 zigen fn-01c's and buddy clubs but no one makes 15's with a 4-114.3 lug pattern Im running tein HE's so i have to get a less than a 38 mm offset.Does any body know what japanese rims i could use?
    There are so many Japanese 15s you could use, it would blow your mind.
    Enkei 92 (relatively common)
    Moda/Modex Dori Dori (Dori 2) Mesh (relatively common)
    Work Equip (not that common in 15" sizes)
    SSR Formula Mesh (common)
    SSR Reverse Formula Mesh (kinda common)
    Watanabe Type F8 (usually expensive)
    Longchamps XR4 (common)
    Southern Ways mesh (kinda rare)
    Riken Mesh (kinda common)
    Those are only the JDM-look wheels, though. Also, that's a very incomplete list.
      thanks for the info. Are these race rims prone to bend?
        Well... depends on how stiff your suspension is and what tires you'll be running.
        My advice: avoid potholes.
          What is the difference in the SSR formula mesh and reverse mesh. They both look the same?
            No they don't. Look harder.
              where can you get longchamps from?
                Any place that imports wheels from Japan. I'd recommend Takumi Project.
                www.takumiproject.com
