Engine Priming
  • Engine Priming
    Ive been trying to get my redtop SR started for about a week now...Everything is on wired up and ready to go, for about a week, needless to say.
    The only time I got it to start was when I primed it by putting gas in the intake manifold...it ran crappy but it ran. It ran for as much fuel I put in too. It eventually would bog down and stall. Now Im thinking this is an injector problem (not firing) Ive checked EVERYTHING and I am clueless.
    Check to see if you put the proper gas line (the return line and the pressure line) in the right spot. It is something that people do every once and a while without thinking. I did it once. Just switch the lines if that is the problem.
