red top sr20det 1/4 mile
  • #31
    yep high 14's is a good estimate for stock SR. Just remember though that the SR responds pretty well with bolt on mods. If you plan on getting more power out of each upgrade, do get your head ported and polished. The stock flow rates for the head are horrendous.
    • #32
      or do that when you break your engine.... cause its not fun taking everything apart for 10hp
      • #33
        dude, check this out.
        http://www.dragtimes.com/results.php...arch+DragTimes
        thats a 240sx at 12 sec in 1/4 of a mile.
        now
        this is a lamborghini at around 11 and 12 sec in 1/4 of a mile.
        http://www.dragtimes.com/browse3.php...i&carmodel=all
        • #34
          Quick question...
          What's the difference between Red Top SR20DET and Black Top SR20DET?
          I was about to point fingers and scream ricer, but then I asked myself, could they be from different cars and are slightly different motors?
          Matt.
          • #35
            red top = S13
            S13 Black top = kouki 180SX S13 chassis
            Notch-top AKA S14 black top = S14/S15
            althought the S15 has different injectors and a different turbo i believe.
            • #36
              sorry this took so long but here is my slip:
              reaction: .682
              I1 : 2.310
              I2 : 6.291
              I3 : 9.594
              MPH (I3) : 75.258
              I4 : 12.349
              E.T. : 14.825
              MPH : 94.462
              a completely stock sr20det 240sx s-13 hatch
              • #37
                It's not hard to make a redtop SR20DET powered car break into the 13's,and still relatively easy to make it run 12's.
                • #38
                  i know i just wanted to see what it ran with no bolt ons
                  • #39
                    Originally posted by Parry
                    all you guys had to say was "slow"
                    lol ok slow
                    • #40
                      I just went to the track last friday and i ran a 14.2 at only 10psi
                      • #41
                        Only 10psi?...Thats a lot of boost for a slow time...
                        • #42
                          Well i have a hybrid FM and running stock turbo, so i get big turbo lag.
                          • #43
                            I'm considering a SR20VET. Any recommenders any nay sayers?
                            Matt.
                            • #44
                              Matt.
                              Fairly new engine in Japan...Might not be as common here...Chances are that the compression are high since it's got variable-valve timing(duh). Other than that I don't see anything else thats wrong...I knew some guys that turboed a VTEC engine, without considering anything else and they fried they're turbo in a couple of thousand miles...
                              • #45
                                30 seconds with google gave me this, so i can't vouch for it, but...
                                What's the going rate on an SR swap these days, if you do it yourself?
                                Last I knew it wasn't that cheap. The real measure isn't the time, it's the time vs. the money invested.
                                There's guys in canada running 11.06 with a 6,000 dollar scirrocco. Not only is that fast, it's cheap.
                                gotta love them Canadian sciroccos
