ok so, i know its harder to drift a car without abs than one with it, but would it be wise to disable the abs on a car in order to practice? then once you get good, you can enable it and drift much better? is there a way to even do this? try not to flame me plz, i just wanted to know how u guys practice.
Non-ABS Drifting
If you wannna disable the ABS, pull the fuse. And for the rest of your questions, try for yourself. I'm not trying to be mean, it's just not a good advice to base things you do in high speed driving off what someone tells you on the internet. (With a few exceptions, mranlet, ghost, smc, grid, etc...)
It's actually no harder to drive a car without ABS than one with ABS on dry pavement, provided you know the car's limits. As long as you know how to threshold brake and have a feel for the feeling of the tires almost-locking, ABS is superfluous in the dry; in fact, not only is it superfluous, it's slower. However, in the rain, ABS is faster. In SoCal, I don't even consider ABS in my "must-have" options list.
ABS isn't this thing that makes drifting a piece of cake, it just prevents the tires from locking for an extended period of time. (Which is something you can condition yourself to do, but it takes time and tires to control it well enough.) Really, there shouldn't be any time while initiating a drift that one should have the brakes on hard enough to lock them.
My new car has abs and I hate it. It does actually prevent you from doing some things by limitting how long you can lock the tires. I drift on gravel, and on many occations wished I didn't have abs. On loose surfaces like gravel and snow/ice, abs is very bad for actually slowing down. Sure it allows you to slam on the brakes and still be able to steer, but there are situations where you DO want all 4 tires locked up or maybe just a pair. I started without abs, progressed without abs, and 9 years later, I still don't want it. I know and prefer a non-abs braking system. I trust myself more on glare ice without abs than with a computer deciding what to do.
As far as drifting is concerned, abs or not abs has little importance. For the most part, braking is never hard enough to lock up the tires. Unless you're coming in very hot or trying to start and hold a slide a ways from the corner entrance, there's not much abs or non-abs systems will affect.
The one thing that abs can never do is lock up and hold all 4 tires still. This is quite useful when things get out of hand and the best thing to do is slide straight to a stop. The sad part is if you have abs, it will basically release the brakes and make you roll again. If you're sliding sideways down the road, this may drive you right into the ditch or something. Having all 4 locked guarantees that your car will remain going in the direction it was traveling until it slides to a stop. With abs, you may or may not do so. You'll start rolling again, and many things can happen depending on angle and which way you're steering. Your car will start rolling and you can't not making it stop.
Abs is one thing I hate on gravel. If I come in fast into a corner, brake hard and the tires start to slide on some loose gravel, my brakes will let off(abs), and my braking ability is cut in half. My only option is to turn very hard into the corner and hope I'll roll out of it well. Non-abs has so much more control at the point of lock up/near lock up(especially on loose/slippery surfaces) once you get used to it. Abs to me is just retarded..or is it for the retarded, lol, sorry bad joke.
I'd suggest to disable it if you can, usually just a fuse. Learn without it. I would on my car if they didn't wire it together with my headlights and cruise control. No abs for me means no low or high beams at night (still have parking and daytime running(half low beam)) and no cruise control.
Originally posted by scirocco
straight from initial d...
However it brings up serious questions. In my opinion ABS can get in the way of hard braking drifts. I dont know though i've been told by many articals writen by dave coleman from sport compact car that modern ABS is suposed to be really good on asphalt. Unlike the ABS from cars like the S13 and such. And that guy seems to be pretty sharp.. but sence few of us drift new cars i think its a safe bet to just advoid it.
omg, just because they said some crap about "ABS" in Initial D doesn't mean that abs can't be talked about on ****drifting.com**** without people trying to make themselves look cool by putting down Initial D and the people that posted. There's nothing wrong with Initial D. It's a fine show as long as you don't let it get to your head. Now if you'll excuse me, I'm late for my tofu delivery run
My 7 doesn't have ABS and I can do anything in it, but the Celica has ABS and have learned how to use it to pull the front end into a corner, it is very cool when you know how to use the features of the car to assist you in manuvours. ABS can be a good thing if you know how to use it, but if you don't it can make things harder.
SMC, Coleman is correct that modern ABS is good, but it just isn't good enough on dry pavement. I've seen dry track tests by very good drivers in Corvettes where the Corvette with disabled ABS laps about .5-sec faster than one with ABS. In the wet, the ABS-equipped 'Vette was two-and-a-half seconds faster.
Originally posted by GRiDRaceTech
SMC, Coleman is correct that modern ABS is good, but it just isn't good enough on dry pavement. I've seen dry track tests by very good drivers in Corvettes where the Corvette with disabled ABS laps about .5-sec faster than one with ABS. In the wet, the ABS-equipped 'Vette was two-and-a-half seconds faster.Last edited by nissanguy_24; 08-07-2004, 06:12 PM.
I think most abs systems do well in asphalt. That's a given. It's predictable and non-deformable. However, when you get on something loose like gravel or snow and ice, it gets to be a major problem. Braking power is dramatically decreased and stopping distances become far greater. As well, on deformable surfaces, locking up the tires actually increases traction and decreases brake distance. The abs system doesn't understand this. The abs system almost needs some form of g-meter to measure deceleration and modulate between rolling and full lock to see what amount of tire lock up is optimum for the surface at any given second. That way on gravel, it may realize that full lock up decelerates faster and will automatically use it cause it works better...maybe in the future.
Until then, abs just pisses me off, lol.
Oh and yeah, you can learn to use it to your advantage somewhat. For example, coming in fast to a corner and having the abs kick in too easily, I do have the option of steering very hard into the corner and roll through. Since the abs prevents tire lock up, I am able to do this while maintaining maximum allowable braking ability allowed by the abs system. Sure it helps in that aspect, but that's not necessarily good. If the abs didn't kick in as easily, I would have slowed down enough to just go around the corner anyways. Instead, I rely on abs and hope, hope that is slows fast enough that I don't go in the ditch because it's so smart that it decreases brake ability down to 20%. Grr!!! lol
OK, now I'm just complaining and rambling...so I'll shut up now.
