2009 Nissan GT-R Specs
Features & Specs
SpecificationsStandard Features
Specifications
Engine
VR-series twin-turbocharged 3.8-liter V6.
480 hp @ 6,800 rpm. 430 lb-ft torque @ 3,2005,200 rpm.
Dual overhead camshafts with variable intake-valve timing.
Cast aluminum cylinder block with high-endurance/low-friction plasma-sprayed bores.
IHI twin turbochargers, one per cylinder bank.
Pressurized lubrication system with thermostatically controlled cooling.
Drivetrain
ATTESA ET-S All-Wheel Drive (AWD) with independent rear-mounted transaxle integrating transmission, differential and AWD transfer case.
Rigid, lightweight carbon-composite driveshaft between engine and transaxle.
Electronic traction control plus 1.5-way mechanically locking rear differential.
Vehicle Dynamics Control (VDC-R) with three driver-selectable settings: Normal (for daily driving, controls brakes and engine output), R-Mode (for ultimate performance, utilizes AWD torque distribution for additional vehicle stability) and Off (driver does not want the help of the system).
Hill Start Assist prevents rollback when starting on an incline.
DisclaimerVDC-R cannot prevent accidents due to abrupt steering, carelessness, or dangerous driving techniques. Always drive safely.
Transmission
6-speed Dual Clutch Transmission with three driver-selectable modes: Normal (for maximum smoothness and efficiency), Snow (for gentler starting and shifting on slippery surfaces), and R mode (for maximum performance with fastest shifts).
Fully automatic shifting or full sequential manual control via gearshift or steering wheel-mounted paddle shifters.
Dual clutch design changes gears in less than 0.5 second (0.2 second in R mode).
Downshift Rev Matching (DRM).
Predictive pre-shift control (in R mode) based on throttle position, vehicle speed, braking and other information.
Wheels and Tires
20 x 9.5" (front) and 20 x 10.5" (rear) super-lightweight forged-aluminum wheels with Gunmetal Gray finish.
Exclusively developed nitrogen-filled Bridgestoneฎ RE070A high-capacity run-flat summer tires, 255/40R20 front and 285/35R20 rear.
Tire Pressure Monitoring System (TPMS).
Optional exclusively developed nitrogen-filled Dunlopฎ run-flat all-season tires, 255/40R20 front and 285/35R20 rear (includes Bright Silver wheels).
Brakes
Bremboฎ 4-wheel disc brakes with 4-wheel Antilock Braking System (ABS), Brake Assist, Electronic Brakeforce Distribution and Preview Braking.
Two-piece floating-rotor 15-inch front and rear discs with diamond-pattern internal ventilation.
6-piston front/4-piston rear monoblock calipers.
Steering
Rack-and-pinion steering with vehicle-speed-sensitive power assist.
2.6 steering-wheel turns lock-to-lock.
Suspension
4-wheel independent suspension with Bilsteinฎ DampTronic system with three driver-selectable modes: Normal/Sport (for automatic electronic control of damping), Comfort (for maximum ride comfort), and R mode (engages maximum damping rate for high-performance cornering).
Electronically controlled variable-rate shock absorbers. High-accuracy progressive-rate coil springs.
Front double-wishbone/rear multi-link configuration with aluminum members and rigid aluminum subframes.
Hollow front and rear stabilizer bars.
Body/Chassis
Exclusive Premium Midship platform with jig-welded hybrid unibody.
Aluminum hood, trunk and door skins. Die-cast aluminum door structures.
Carbon-reinforced front crossmember/radiator support.
Back to Top
Standard Features
Exterior
Wide-beam headlights with High Intensity Discharge (HID) low beams.
LED taillights and brake lights.
Dual heated power mirrors.
Flush-mounted aluminum door handles.
Body-color rear spoiler with integrated center high-mounted stop light.
UV-reducing tinted glass.
Audio/Navigation/Performance Monitor
Digital Boseฎ audio system with AM/FM/in-dash 6-CD changer and 11 speakers including dual subwoofers.
HDD Music Box system, including hard drive with 9.4 GB for audio storage.
MP3, WMA and DVD audio capable. In-dash Compact Flash card reader.
HDD-based GPS navigation with touch screen.
Driver-configurable performance monitor, developed with Sonyฎ Polyphony, with graphical readouts of vehicle data and driving data displayed on a total of 11 screens.
7-inch WVGA high-resolution color-LCD display for audio, navigation and performance monitor.
Interior
Automatic Temperature Control (ATC).
Electronic analog instrument cluster with multi-function trip computer and digital gear indicator.
Power front windows with one-touch auto-up/down feature.
Intelligent Key system with pushbutton start. Power door locks.
Cruise control.
Tilt/telescoping steering column.
Bluetoothฎ Hands-free phone system with voice recognition.
Seating/Appointments
Leather upholstered front seats with perforated Alcantara inserts.
8-way power front seats with entry/exit switch for rear-seat passengers.
Driver-shaped bucket seat.
Dual individual rear seats.
Heated front seats.
Leather-wrapped steering wheel and shift knob.
Drilled aluminum pedals.
Safety/Security
Nissan Advanced Air Bag System (AABS) with dual-stage supplemental front air bags, seat belt sensors and occupant-classification sensor.
Driver and front-passenger side-impact supplemental air bags and roof-mounted curtain supplemental air bags.
Front seat belts with pretensioners and load limiters.
Nissan Vehicle Immobilizer System.
Vehicle Security System.
DisclaimerPlease keep in mind that air bags are a supplemental system and must be used in conjunction with a seat belt. Never let children 12 and under ride in this vehicle unless the front passenger air bag on/off switch has been installed. Side air bags and side curtain air bags are designed to inflate in higher severity side collisions and inflate on the side of the vehicle impacted. Please see your owner's manual for more details. Inflated air bags shown for illustration purposes only. Actual air bags deflate after deployment.
Back to Top
* Japan-market features and specifications shown.
Bridgestone is a registered trademark of Bridgestone Corporation. Brembo is a registered trademark of Freni Brembo S.p.A. Bilstein is a registered trademark of August-Bilstein GmbH & Co. Bose is a registered trademark of The Bose Corporation. The Bluetooth word mark and logos are owned by Bluetooth SIG, Inc., and any use of such marks by Nissan is under license. Dunlop is a registered trademark of Dunlop Tires. Sony is a registered trademark of Sony Corporation of America.
* Privacy Policy
* Copyright
* Nissan USA
close x
Features & Specs
Specifications
Engine
Drivetrain
Transmission
Wheels and Tires
Brakes
Steering
Suspension
Body/Chassis
Back to Top
Standard Features
Exterior
Interior
Cruise control.
Heated front seats.
Safety/Security
Back to Top
* Privacy Policy
* Copyright
* Nissan USA
close x
