ENGINE TUNING DVD SERIES (Vol.1) by DRIFTING.com
  • ENGINE TUNING DVD SERIES (Vol.1) by DRIFTING.com
    <iframe width="640" height="480" src="//www.youtube.com/embed/u5LgJMuqEaM" frameborder="0" allowfullscreen></iframe>
    DVD ORDER PAGE - Engine Tuning Vol. 1[/B]
    http://store.driftingshop.com/pentudvdaplp.html
    Nice!!!! I like it!!
      question
      Is this with a SR engine or KA24DET?
      I'd imagine you guys go into some of the math behind duty cycle ect so people with either engine can learn from this?
      Very interested in this DVD, is it exclusive to drifting.com?
        The main focus of the first DVD in the Engine Tuning Series is to show how to setup and operate the software.
        Drifting.com is currently the only company that is authorized to sell this DVD.
        thank you
          When will this DVD be released?
            we have been sitting on the raw content for a few months but we need to re-film the dyno section with a video capture.
            the re-filming schedule has not been locked down, we might know more within 1-2 weeks
              we have been getting several emails and calls about this DVD so we will do our best to post updates on this thread
              -we plan to re-film near the end of July
              -the new version will been done with a video capture so the resolution is clearer
              The outline is done but more topics will be added after we apply the suggestions that have been submitted to us.
                we are restating the objective again because this is asked a lot...
                Vol. #1 will focus on how to operate the basic functions of the AEM EMS Software on the dyno
                  Any updates? Release date?
                    the content that we have can not be released
                    we are refilming within 1 or 2 hosts by either Sep-Oct or starting in January.
                      new update,
                      we might be able to lock this down by September, we will know more by tomorrow
                        Submitted Suggestions; By nutz @ SRT Forums
                        Opening the software
                        Loading a base map (always start with AEM’s base)
                        Setting up correct sensors for application
                        Setting up injectors and fuel pressure
                        Connecting to the ECU (can be difficult with obd-serial port)
                        Uploading your map
                        Setting the o2 gain (so gauge reads the same as the EMS sees)
                        THE START UP (yea now were getting some where)
                        Adjusting start up/warm up parameters
                        Getting it to idle (just for basic tuning)
                        Double check your timing/fuel maps (changes in sensors might make the map dangerous!!!)
                        How to do baseline (non-boost) VE mapping for A/F (low load)
                        (boost comp theory) predicting A/F load cells
                        How to set up and interpret logs (very very important)
                        Setting up o2 feed back
                        Tuning load A/F
                        Ignition timing tuning (dangerous subject)
                        Knock sensor setup
                        Setting up sensitivity for false knock
                        How much to pull/add and how quick
                        Putting it all together for drivability
                        Throttle fuel correction
                        Final idle adjustments
                        Rev limiters/2 step
                        Fan on –off
                        ADVANCED
                        Anti-lag theory and how to safely use it
                        Traction control ????????
                        Injector phase theory and how to (changes for boost comp and cams)
                        Staged injectors theory
                        How to set up inputs/outputs
                          We are schedule to re-film next weekend
                            Re-filming takes place tomorrow
                              over 3 hours of usable content was captured today
