the editor's copy will be completed by tomorrow so it can be sent out for review
ENGINE TUNING DVD SERIES (Vol.1) by DRIFTING.com
Disc 1 out of 2 has been released as an "early copy"
http://store.driftingshop.com/vol1di1eco1h.html
We are getting calls each day about this DVD series so here are a few answers to our top questions;
1-What is "documented" in the 2 Disc Set?
-Basic Template Setup
-Data Logging to make fuel adjustments
-Knock Sensor voltage readings
-Introduction to Basic software setup
2-Does this DVD cover theory?
NO, this documentary covers some of the basic operations of the AEM EMS Software
3-Disc 1? Disc 2? Vol #1?? I am confused???
Vol#1 has 2 Discs (Disc 1 + Disc 2)
4-Is this a manual?
NO, this is a documentary that runs for about 3 hours and 30 minutes
5-Why did we produce this DVD?
MANY customers who purchased our other titles called and requested that we produce a DVD that documents engine tuning
6-Does this DVD cover everything about tuning?
NO, This is JUST Vol #1, which runs for over 3 hours.
To cover most of the general areas we would need to release a few more volumes and the total run time for the series would be around 8 hours.
7-What are your future plans?
Our plan is to talk to the customers who purchased to first Volume so we can outline the topics that will be documented in the next DVD.
Disc 1 and Disc 2 of Vol.1 have been released.
Vol. 2 Plans
-February; Collect feedback from Vol. 1 customers
-End of Feb./Early March; Draft an outline based on the feedback/requests
-March; Discuss the outline with the hosts to see what can be covered
-March Line up a car and schedule time on a Dyno (This may take time, so if we have more option then this will prevent production delays)
-APRIL/MAY (TARGET) Film
To summarize the filming and editing will not take that much time, however the planning will take time so we document the correct material.
Submitted Suggestions for Vol2
VSS BOOST CONTROL (LOG/TUNE)
THROTTLE BOOST CONTROL (LOG/TUNE)
TRACTION CONTROL!!!(LOG/TUNE)
IGN./FUEL IAT (LOG/TUNE) little theroy easy
IGN./FUEL COOLANT TEMP (LOG/TUNE) little tune theroy easy
THROTTLE FUEL CORRECTION (LOG/TUNE AND WHEN TO USE) small amount of theroy on Throttle blade angle and VE
SETTING UP INPUTS
SETTING UP OUTPUTS
N2O MAP CONTROLS AND ACTIVATION ?????
COIL ON PLUG ????? POSSIBLE
ADVANCED LOGGING (LOGING CRANK ANGLE, FIREING ORDER IN FAST MODE)
PID CONTROLS (THEROY??)
SHIFT RETARDS
*****AEM EMS THEORY****
HOW THE BOX MAKES CALCULATIONS
IGNITION TIMING
DYNO TUNING"
<img src=http://www.drifting.com/tuningss1.jpg>
http://store.driftingshop.com/pentudvdaplp.html
<img src=http://www.drifting.com/tuningss2.jpg>
<img src=http://www.drifting.com/tuningss3.jpg>
<img src=http://www.drifting.com/tuningss4.jpg>
<img src=http://www.drifting.com/tuningss5.jpg>
