ok so i know this has nothing to do with drifting, but it somewhat is connected to automotive. i made a cold air intake for my computer, but the air isnt better. my cpu used to be 104f but when i put the intake in, it goes to 106f. anyone know what's wrong?
cold air intake
It's hotter with the intake right now probably because some furnace duct is forming a draft that you don't know about that is aimed at the intakes opening. What might work is if you got one of those super high power fans and stuck it to the end of the intake. You could always make a water cooling system too, I was thinking about one for my computer, they have radiators that you can make stick out the front too.
1.That intake is done all wrong.Look on any car,notice where the intake is located,it is near an area where air can easily be sucked in(near the wheel well in a lot of cases).Your intake points up,it's more like an exhaust than an intake.You should have it go out,then turn right,where you then conveinently place a fan that you crank on high.This will now turn you cold air intake into forced induction,haha.
2.With all that power,you need a good cooling system,look here.
http://www.thermaltake.com/coolers/aquarius/a1681.htm
