3" exhaust on my 240.... (help)
  • 3" exhaust on my 240.... (help)
    I was thinking about putting 3" exhaust on my stock 1997 240sx cept I don't know if it will work for the 240 I forgot what they called it because it was stock like there wasn't gunna be enough air flow or pressure or something but if it is possible where can I get the parts and what are all the parts that I need to put 3" exhaust on my 240
    a 3" exhaust on your car will cause in a lack of back pressure. it wont really help you on the low end but at the top end it will give you a little bit more power. the best thing to add to your car to make a 3" exhaust efficient is a turbo.
      that thing you are talking about it back pressure. It supposedly (or maybe its been proven) gives the motor more torque. If you plan on adding a turbo or SR20DET in the near future, just get a new intake and maybe a cheaper or no exaust. Once you get a turbo system or motor, the turbine will deliver plenty of back pressure, so then a 3 incher would be grand.
      However if you just wanna keep it NA, stick wit a 2.5 or 2.75 inch exaust
        SO if I did an SR20DET swap it will give enough back pressure to run a 3" exhaust with any problems?
          Both Raemi and Uberspeed should not have posted. Their information is incorrect.
          A proper 3" exhaust on the KADE will give gains throughout the rev range, not just up high. An increase of 8-12whp isn't uncommon.
          3" is ok for an SR swap.
            can i see dyno sheets on this?
              Yes, you can.
              Post number 14.
              http://www.zilvia.net/f/showthread.p...t=exhaust+dyno
                Yes, you can.
                Post number 14.
                thanks but i want a dyno sheet of a 60mm exhaust to compare it to as well (if possible).
                  It just so happens I have one of those too.
                  (Dyno done by S14DB on Zilvia.net)
                    what a n00b post.
                    i love you, tell andy to get my stuff
                      I put a 3" on my KA and it had more power all around, I didnt lose any power I could feel but I did feel that it was faster, more than I would expect from just adding an exhaust
