sr20 ignition issues
  • sr20 ignition issues
    ok the ignition stays on constantly, i cannot start the car with the key, either the ignition relays starts buzing or the acc relay on the drivers panel starts clicking, i also noticed that the relay coming off the fuse panel right underneath the clutch pedal clicks.... when i jump the starter off to start the car, i have to let 5th gear out to kil th emotor the key doesnt do anything.... i can start the car and everythign with out it. i did a auto to manual swap. but i have the wires jumped off as i should.... if any one has any clue as to how to solve this or if anyone has had this problem before any help would be much appriciated , thanks
    Matt
    double check and triple check your work. If you dont see anything wrong, have someone that has done the swap look it over. I would only be able to help you if i was there to look over what you have, sorry. But here is a helpful site that you can run through and possibly find what your mistake was. http://www.srswap.com/faq/index.asp
    If you still cant figure it out, post in the Zilvia.net forums, they are always helpful. best of luck
      agreed with tokyo.. if your car started fine with the ka.. then u wired something wrong.
