BMW drifters and their set up
  • BMW drifters and their set up
    I know there are a few people who drift bmw's and i was wondering how they set up their car to drift. What suspension did you use? what other mods have you done to your cars.
    I have 97 328is if that helps.
    I have searched but i mostly found threads about photos of bmw drifting but nothing really on their set up.
    thanks for the help.
    Well i had a 96 328is that i did a little drifting with basically i just thru some lowering springs at it and turned off the traction controll you have to enter corners at extremly high speeds to get the tail to kik out i find that feint techniques work well basically juke the wheel twards the outside of the turn then wip it back inwards to kick the tail out then lay on the gas if you get to side ways just let offa the gas and return the wheel to zero an it goes straight be carfull though if you get to side ways its flat spin time
      I've been drifting a e46 325Ci for about three years now. It was a struggle at first, because of the differential (BMW stopped putting limited slip differentials in all non-M series cars in '95) - so I drifted for over a year with an open diff... which, around the time I put the KAAZ in the car, wasn't half-bad to slide. BUT - once that KAAZ went in, the car became EXTREMELY driftable.
      I've seen people like Sean Love taking the limited slip out of the Z3 (e36 as well), and using them as a direct bolt-on for e36 3-series. This doesn't work for e46, but would work for you.
      My suspension setup until now has not been very condusive to drifting: Bilstein Sport Shocks/UUC Springs/UUC Swaybars: no adjustability, and way too soft for such a heavy car. I would get too much body roll, but knew how it all responded enough to make ends meet. My suspension setup has completely changed in the past three weeks, with Turner Motorsport aluminum subframe/differential bushings, Bilstein PSS-9 coilovers, Turner Motorsport rear camber arms, KMAC front camber/caster plates. I haven't had a chance to thouroughly test the new setup & dial things in... so I can't really comment on it just yet.
      Suspension aside... the single most important mod I've done to that car to make it driftable is the KAAZ LSD. If I had to start the car over again tomorrow, that would be the first thing done. We've also been working to reduce the weight in the car, which has helped immensely.
      I hope that helps! Let me know if you have any other questions. I'd be happy to give you a complete breakdown of all the mods I've done if you want. I would LOVE to see more BMW's out there! They are very capable... albeit, a far cry from a budget drifter.
        i would just like to point out without pissing you off that their are easier and cheaper platforms to start with. people like andy have had pretty good success with his setup, but i bet he would have progressed even faster if bolt on power had been cheaper. i actually started on a bmw, and had a really hard time learning for my first 8 events or so. my problem was i was blindly modding the car, i suppose because i had nothing better to do. my setup was an m3 with ground control coilovers/springs setup, super charged motor, completely stripped car, racey everything, big ap racing brakes, ect. i had no idea what i was doing lol.
        i jumped in a stock 350z, tossed in a diff, and started learning at an increadible rate. let me restate that i sucked in my bmw, i'm not sure why other than i'm not a mechanic and the thing was always giving me small trouble. now with all my other japanese toys i never touch my m3, and its been sitting without being taken to an event for over a year. i've probably put a total of 20 miles on it in 12 months. i've always thought the e36 m3 is over rated, but for the time period it was built in, i suppose it was pretty darn good. just look at how bad the 95 mustang was.
        i had an e39 m5 though, and that thing was awesome once you got used to the weight. the stock clutch was weak, as well as the steering angle, but you absolutely didn't need anything extra to drift around happily with it. screw japanese chasers, gs300s, cefiros.... the e39 m5 is an amazing 4 door that you can buy for mid 20s now, that is awesome stock. i'm going to pick one up eventually again and use it as a drift car.
          This is VERY true. BMW's are an expensive drift car, no doubt. I don't even want to begin to assess the amount of money that has been A: put into the car in modifcations; B: put into the car in maintenance/repair. Hahaha... actually, I just did a rough estimation in my head on what I've spent repairing damage from drifting into things... and it's scary.
          While I may have had a certain level of success with the car, I feel that I have definitely hit a glass ceiling with it... because of power (179hp/168tq - 3300lbs). Aaron is right - bolt on power (big power) for these cars (at least mine) starts at $5k. Now that I'm close to having the car where I want it with the overall setup... big power is next on the list - but at that price still not close.
          I haven't done anything to increase steering angle in my car... and it actually gets a surprising amount angle on track. I don't really know how it compares to the e36 chassis, though. I'm using an OEM e34 M5 clutch/pressure plate - which is rated for 400hp... and stands up to my 179hp + massive (and I do mean massive) amount of clutch kicks without issue.
          I'm not a mechanic either (well... I should say wasn't). BMW labor is just as expensive as the parts are... and as I break things, I have to learn how to fix them, because paying BMW $115/hour to fix it is out of the question.
          So while BMW's are very capable drift cars in a functional sense... the expense may overshadow that functionality to a certain degree.
          I guess it depends on how far you plan on going with the car.
            massive doesn't even begin to describe it. when i drove with you at the feeder series, on the dry day before, we were laughing hysterically counting your clutch kicks going around the course. i've NEVER seen someone use so many of them, i think the highest we counted for one lap was 15 or so. we caught you clutch kick the first corner FOUR times. it took me awhile to realize they were clutch kicks, as you used so many of them i thought it was just the sound of your throttle work!
            you do drive your car very well though, and its fun watching someone overdrive the car to its potential on a track, simply man handling it and trying to squeeze out every last bit of hp.
              Thanks, killa! I appreciate the kind words. I never really thought of it as over-driving the car... but now that you mention it, it sorta makes sense. Those constant stabs at the clutch have definitely worked their way into my style. I have fun driving like that, although for judged runs I try and keep more of a smoothe foot - since that seems to be what most judges are looking for these days.
              Now... GO GET THAT M5, and we will battle!
                I just posted my press video for 2006 in the video section - it has a full list of the modifications to the car prior to the adjustable suspension. Hope that helps!
                Click here
                  A certain level of success? Hell man you tear it up dude. Any chance someone gets to watch Andy slide is fun, he is consistant, rarely makes mistakes and goes ball out at any event he goes too no matter what may happen (Black Hills event "Shudder" broken subframe ftl).
                  The car was a little too nicey nicey though but it is starting to look like a battle hardened veteran now Mr Sapp. Keep it up.
                    If you are running a regular e36 reinforce the rear subframe. that sucker's going to tear right out under hard driving.
                    i second the kaaz LSD. this mod will feel like you got new suspension for the car. the stock bmw lsd found in other models only has a 25% lock if i'm not mistaken.
                        Aww... thanks buddy!!! Bwahaha... she's starting to look more and more like a war machine every day! She's definitely come a long way. Nothing quite says battle like a rollcage and woodgrain!
                          Originally posted by FreeThinker
                          I would recommend calling turner motorsport and ordering the rear subframe reinforcement panels (they are OEM pieces that were used on the M3 chassis), having them installed professionally and if you get a cage done, have the cage braced into the rear shock towers (for a later upgrade) and also braced through the trunk floor into the subframe pickup areas.
                          Good point Sean!
                          If you're going to be doing serious drifting in a BMW, rear subframe reinforcement is a must. Both e36 and e46 subframe mounting points are notoriously weak. They tried fixing the problem on the e46 with a cross-member that connects the front two mounting points - but as a result, directs that stress to the left rear mounting point.
                          About a month ago, I cracked my subframe where the differential mounts to it, and upon removal of the entire subframe, I found that very mounting point had begun to fatigue and crack. The subframe was on it's way to tearing itself out of the car. Luckily, I caught it at the right time. Both myself and TMS were surprised that the damage was so minimal in respect to the amount of stress I have put that car for the past three years.
                          Click here for a full write up.
                          Turner Motorsport is a godsend in the subframe department. All of their racecars are fully reinforced with the kits they sell online (I would highly recommend professional installation). They also offer a full line of aluminum/race bushings (subframe, differential, trailing arm, etc) that make a world of difference. I stand by their products 100%.
                            My bmw is a early E30 325is with factory 3.73 lsd.There's a couple of E30 drifters on here,but anyways I drifted the car
                            100% stock, at first, for two reasons. 1) Wanted to get use the feel of the
                            and 2) Had no money to spend on mods haha.
                            But now that I gotten use to the car and got a job at a friend shop ,
                            here's my setup (so far)
                            -Koni Single Adjustable Shocks/Struts.
                            -Ireland Engineering Stage 3 springs(which are seen as the best springs for the E30s)
                            -Z3 steering rack conversion,only 2.7 turns lock to lock vs the stock 4 turns.
                            -Ground Control rear shock mounts
                            -Ireland Engineering Exhaust
                            -Front Zimmberman cross drilled rotors.
                            -Akebono ceramic pads.
                            Engine is basiclly stock except for a rebuilt head.
                            Hope that gives you or possibly anyone interesting in drifting a e30 an idea.
                              any chance youd wanna sell that E30? :-D
                              this is the best thread that drifting.com has seen in years.
