Since it's useful information when deciding on swaps, etc... everyone post engine weights here.
Engine weights.
[ Engine weight engine weights engine weigh transmission weight transmission weights ]
Without transmisison (figure +100-150lbs)
A12 87 kg 192 lbs
A14 93 kg 205 lbs
L18 118 kg 260 lbs
CA18ET 118 kg 260 lbs
QR25DE 121 kg 267 lbs
CA18DET 128 kg 282 lbs
SR20DE 139 kg 306 lbs
SR20DET 149 kg 328 lbs
FJ20ET 166 kg 366 lbs (205 hp)
KA24DE 167 kg 368 lbs (est)
With Transmission:
SR20DET 490 lbs
RB25DET 667 lbs (280 hp)
VG30DET 589 lbs
Ford Small Block V-8 487 lbs
Chevy Small Block V-8 575 lbs
-MRLast edited by mranlet; 02-11-2004, 10:29 AM.
Originally posted by ACDSupra7
Just engine weights. It's more of a personal thing, but I thought it could be useful for others as well. Well, others that are willing to use the ::cough:: seach button ::cough::
My tyranny weights about 180lbs
My 7M-GE alone weights 300LBS DAMN CAST IORN!
Good call - fixed it.
I hope that the words at the top work in the search engine and thanks!
Don't lip the cast iron! RB's are all iron... Iron is less susceptable to warpage and dissapates heat better than :: aluminum. You can make more power safer even though there;s more weight
