180sx brake caliper fit?
    the only difference between sentra and altima rotors are that the sentra rotors are 5mm larger in diameter, which means if you use altima rotors the pads will hang over the edge of the rotor 5mm which doesn't matter because it doesn't effect braking capability or reliability.
    If you are using true jdm silvia calipers then you do not need anything other then the silvia caliper assembely. you only need the slider brackets if you are using the altima calipers.
      Oh ok thanks a lot, I have the real s13 silvia calipers, but altima rotors, hopefully this will help braking b/c I nearly died the other day up the crest
