engine torque damper
    ok this is buggin me but what is an avatar?
    chas asked you to remove yours and when you said "hope thast better" it didnt look like anythign was different
    sorry for the dumb question
      the pic under the name
        ok thanks alot for clearing that up for me
        sorry for changing the subject
          dont change the subject!!! lol
          just worried about my motor!
            haha sorry sorry!
            man you guys respond quickly
            umm the only thing i know is that the sr makes bad vibrations when swapped and the torque dampener give you back some of the HP lost with engine vibration so thast deffinatly good,
            as far as down sides i have no idea, never heard.....sorry
              thats ok, thanks for the input
                post whores suck!!!!
                dont whore up my post
                i want good info
                not just BS like "i heard those were good."
                  umm sorry.....?
                  and sorry you got so flamed on the other thread but you were being very opinionated....
                    i want good info
                    hi
                      i really dont feel flamed, it just sucks when you ask a legit question to a forum and the only input you get is lame. sorry, if i was here to bs, i would not be in the tech section
                        I'm curious about this torque dampener. Is it the same as say the rubber piece they attach between the motor and chassis on the top of the engine on some cars? I assume this is just the shock form of that same thing, right?
                        Stronger motor mounts would do the same thing, correct? I know this helps keep the shifter from moving around on you when you're playing with the throttle. I guess it's just a matter of what's available for the car as well.
                          Well An engine torque dampner is something that braces or helps the engine stay placed better under high loads.Kinda like stiffer shocks for better handling during harder connering..Mostly helps the clutch chatter on rx7's
                          Here is a Pic of the racing beat one for the FC3S
                          It attached right onto the bolts connecting the tranny and engine Then goes into the side of the engine bay fowards of the firewall about 3 inches...
