Top Mount Intercooler or V-mount for a SR20 on a 240?
  • Top Mount Intercooler or V-mount for a SR20 on a 240?
    Does anyone know where to get a top mount intercooler (or V-mount) for a SR20 on a 240? I can honestly say i am the mecca of number of online stores (the ones i can read and cant) and i have never seen an top mount intercooler!...please....someone guide me with your knowledge
    i thought top mount were for boxer engines only? and V mount is aviable from singnal
      Top-mount would require an excessive amount of clearance over the top of the engine.
        yeah
        I wasnt sure of the diff between top and V-mount....now i know its V-mount
          Try Signal Auto, lots of $$$$$$$$
            be preparded to spend some loot on a v mount set up. a vented hood is a necessity with this set up. also there is going to be lots of fabrication involved. unless you can weld thats expensive. not to mention a good e fan set up.
              i had a vmount on the fd before the "accident" (dun dun dun erie music playing in the background)
              it wasnt that bad, than again rotaries have a ton of room in the engine bay. vmounts have tons and tons of pluses, the only negative is the occasional belt change and u cant see it through ur bumper, so u dont have that menacing fmic look but its alright to me seeing as the vmount lowered my temps Greatly, never needed to worry about overheating.
              i just ordered another one from chuck huang at rotary extreme i think it costs like 2300 so ya they are expensive
                not really, thats the price of a decent coilover kit, but then again i dont have $1 to my name...and my car dont even have a battery
                  Most V-mount systems are custom. I have some pics I will post but you will have to rake back the radiator and put electric fans on it. You will also need a vented hood and ducting of some sort is a VERY good idea.
                    Here is another
                      And another...
                        You get the idea. This is my last one if you want more just ask.
                          Do it yourself - see my sig.
                            Doing it yourself is alot of work with careful measurements and alot of fabrication and special care to bleed your coolant system properly, etc. Signal charges about 3k for the v-mount service + the cost of parts. before going to some extremes such as v-mounting, figure out your budget, your power prospects, and the function of your car first.
                              Why do you want a top mount? SO th eheat off your exhaust manifold and valve cover can waft over it and you can spend an hour to change the spark plug instead of just popping a cover off and checking them casually.
